hahah thank you very muchYou've got it, grasshopper.
Looking at all the voltages often make it clear what's happening in the circuit.
The op amps positive input voltage is slightly lower than the negative input so its output is low, and there is thus no voltage to turn Q2 on.
It would appear that your supply voltage is only 4.85V, not 5.1V as you earlier stated.
But how did you measure 4.85V, 4.83V, and 4.81V for the same supply voltage?
(Which brings up the point that all those nodes are at the same voltage so only one measurement would have been required.)
Is the source a battery that was nearly discharged?
So you should use a reference voltage source, (such as the cheap TL431) to provide the voltage for IC1a's (-) input so that any supply voltage change doesn't affect its trip point.
