It's called an insulation displacement wire-to-board connector.Can somebody tell me what this connector is?
If I remember correctly, the distance from each pin was 2mm apartWelcome to AAC!
Some sort of IDC connector. Dimensions would be helpful.
Correct, unbranded. Theyre part of my stereo In my 06 Silverado. They're made by Delco electronics and it says made in MexicoTo be precise, it’s a discrete wire idc connector.
Most of the major connector manufacturers have them in their catalogue, you will need to trawl through them using the above description until you find it.
I can’t find it in JST, 3M or TE although they make similar products.
Could be a Chinese brand which may be very difficult to find.
I assume the connectors you have are not marked ( branded) in any way.
