Here's the (non ideal) diode equation I referred to.
Following is a graph I made of the ∆V across a real pair of diodes in a rectifier, using the diode equation to fit the data. You can see that in the "normal" range of use (up to about 1A for this recitifer), the ∆V is nearly constant. But at high or low current, it deviates more.
