Connecting DPDT relay to two different solenoid valves
pr123
Joined Mar 13, 2015
30
I am trying to trigger/switch two Solenoid valves (24VDC) with only one DPDT relay (24VDC) is that possible and can anyone help me with its circuit diagram? relay is Omron make with base.
Thank you
28,688
You use a N.O. contact on each of the DPDT contacts to switch the solenoids individually.
The coil is energized by the system you are using, a reverse connected diode should be used across the coil of the relay and also across each solenoid, particularly if there is electronics present.
