Most pre LCD scopes have all metal case - the dangers of that much metalwork at floating potential, should be obvious even to someone who was dropped on their head a lot when they were little..............................This is the problem, the scope should always stay at ground potential, and you should use an isolation transformer to isolate the measured circuit. It seems to me that often when people talk about isolation transformers it is not quite evident if it is the scope that should be isolated or the device.
It's on my list.........someday.The isolated differential probe is the way to go. I finally got one for home
