I would like to hook up 3 moniters to a computer to have a photo slide show, each monitor showing a different photo. Can this be done? If so how? Thanks.
When you say video card, do you mean a SD card? ThanksThe easiest way is to use video card with three outputs, make sure the card can actually do three simultaneous outputs. Many cards these days have three outputs, but often only two of them can work simultaneously. Run three instances of slide show program, place the window of each instance on each monitor.
Next choice is using two video cards. Connect two monitors to first card, connect third monitor to second card. Run three instances of the slide show program.
Do you have any suggestions? I am not going to show anymore then say 50 photos. Probably less, like 20 photos.Yes, you will need to install a video card capable of adding two more video outputs than you have now.
Thanks. I am taking suggestions.Yes, you will need to install a video card capable of adding two more video outputs than you have now.
No.When you say video card, do you mean a SD card? Thanks
