compatible driver module for AC Servo Motor
skyr6546
Joined Mar 22, 2019
73
Hello ACC Community!
I would like to control the AC servo motor from the microcontroller. I want the servo to return some position, servo start, servo stop, return to a home position
I am looking for information to drive the AC servo motor https://www.ebay.com/itm/200W-Delta...20V-3000rpm-Keyway-Oil-Seal-New-/122118865696. I know microcontroller can’t drive AC servo motor directly.
I see, many drivers are available in a market.
Can somebody suggest me compatible driver module for given AC Servo Motor
drc_567
Joined Dec 29, 2008
1,156
... An AC servomotor requires a specific amplifier. A DC analog control signal is converted by the amplifier module to an AC waveform that is compatible with the motor. For the various options that you list, you might want to inquire with a commercial package developer such as Galil. The motor which you have listed only shows to have 0.64 n-m static torque, which is less than one ft-lb. The rated watts apparently occurs at some higher motor rpm.
MaxHeadRoom
Joined Jul 18, 2013
30,815
Do you want a pulse type control or ±10vdc analogue ?
Is it actually a AC servo motor or a BLDC, physically they are practically identical, the only difference is in the commutation fitted, do you know if it has hall effect type, if so it is BLDC control.
I generally use BLDC and A-M-C drives, but these have the ±10vdc, if you need step direction there are quite a few options.
AC is not so common.
Max.
MaxHeadRoom
Joined Jul 18, 2013
30,815
Link show it's a AC servo motor. My question is how to drive this motor if want to control it from microcontroller
You need to find out if it has any kind of commutation device, and if so, what is the nature of it, resolver etc?
According to the spec sheet, it has a 17 bit incremental encoder.
Which it most likely also uses for commutation.
Max.
