Common Emitter BJT amplifier
t_n_k
Joined Mar 6, 2009
5,455
I think it means AC output voltage - so it relates to the overall gain of the circuit and the AC input voltage.
Petrucciowns
Joined Jun 14, 2009
62
Now that I look at it more closely I see that you're right. It's the voltage of the input resistor x the gain. I just cant figure out how to find that voltage. How is the input current found?
t_n_k
Joined Mar 6, 2009
5,455
You can use the voltage divider equation to calculate the AC base voltage.
You are given Zin=3.12k - so you have a voltage divider comprising the source [10mV], the 600 ohm resistor and the input resistance [3.12k].
This will enable you to obtain the AC voltage at the base.
You are also given the gain relative to the base input as 60.2 so with Vb (AC) known form above calcs and Gain known you should be able to obtain Vout (AC).
Petrucciowns
Joined Jun 14, 2009
62
Sorry for being a little slow ,but what would the equation look at. I tried 3.12k /3.12k + 600 The answer comes out with the same number just 100 times bigger so I know I'm not doing it right.
t_n_k
Joined Mar 6, 2009
5,455
OK - let's go through the calcs.
Given source voltage = 10mV
Vbase (AC) = 3120/(3120+600)*10 mV = (3120/3720)*10 = 8.39 mV
Gain = AvTR = 60.2 (per your data)
Vout (AC) = Gain * Vbase (AC) = 60.2 * 8.39 = 504.9 mV
Which is close enough to 505mV
