Coincidental numbers
neonstrobe
Joined May 15, 2009
200
Just checking an algorithm I stumbled on a slightly interesting result. The expression is
5/(1.5**4).
Needs answer to 9 decimal points.
dl324
Joined Mar 30, 2015
18,476
What makes it interesting? There's no way to get the wrong answer because they included parenthesis to force an order of operations that's already understood.
neonstrobe
Joined May 15, 2009
200
Sorry. I'll rephrase that in Basic: 5/1.5^4 (without redundant parentheses).
Just means raise to the power. It's the Fortran version.
Wendy
Joined Mar 24, 2008
23,857
\(x=\frac{5}{1.5^4}\)
Practicing my LaTex skills.
The M$ calculator can handle more than 8 digits.
I get 0.98765432098765432098765432098765
Wendy
Joined Mar 24, 2008
23,857
\(\frac{987654321}{123456789}=8.000000072900000663390006036849\)
Trolling Moderator style.
wayneh
Joined Sep 9, 2010
18,170
Just curious. What did you use to get that many digits? Excel drops anything past 729. Another calculator I have gives ...72900001 using double precision and ...72900000664 using float80.
neonstrobe
Joined May 15, 2009
200
Yes, that's why I said to 9 decimal digits of precision. The repeat count gets approximated.
Could not have been exact with a factor of 3 in the denominator, really!
My old calculator displays 9 digits but has an accuracy to about 12. You have to subtract some MSD's to see the remainder. Which is how I came across this.
