Coil Saturation Current Causing Damage
Progtheater
Joined Sep 16, 2013
4
Hi, this is my first post here, so hopefully i'm posting in the right place.
So my question is, if a simple DC circuit with a series connected inductor and resistor needs 5A for coil saturation, the components in the circuit might overheat and get damaged if allowed to flow for a long time. Is there anyway to mitigate this risk??
I tried to google for solutions but i'm not getting anything. I might be using the wrong keywords though, so if anyone knows the right term i should be googling or any solutions for this, please share it with me. Thank you in advance.
Progtheater
Joined Sep 16, 2013
4
The nature and purpose of the coil are not stated. Just need a method to keep the coil saturated at 5A while reducing the risk of damage to the resistor.
Progtheater
Joined Sep 16, 2013
4
WBahn: What if i am unable to select ideal components that can run on 5A for long periods of time, are there any possible circuits or components that can be added to solve this problem?
Thanks for all the prompt replies.
#12
I think there is something strange about protecting hypothetical parts from overheating, but that seems to be the heart of the question.
With a voltage causing a current through a resistor and a coil, which part will get hot? Find that and you will find what you're trying to protect from heat.
Progtheater
Joined Sep 16, 2013
4
This topic comes from a electrical safety course i'm currently attending, explaining the strange question.
Thanks to everyone for giving me pointers.
strantor
Joined Oct 3, 2010
6,875
Throw it in a cooler full of dry ice.
But seriously, this is one of the more badly written questions I've seen in a while (nothing against you, I'm sure you didn't write it). If you MUST keep 5A flowing, and 5A is enough to cause it to overheat, then the only option is active cooling. Use a heat sink mountable resistor bolted to an aluminum extrusion with a cooling fan. For the inductor, I don't know, perhaps put it in an enclosure full of mineral oil and cycle the oil through a radiator.
Maybe the question would make more sense if I was attending the class and had the context in which it was asked.
Brownout
Joined Jan 10, 2012
2,390
I disagree:
Guess it's all in how you read the question.
t06afre
Joined May 11, 2009
5,934
I have also problem understanding the question. It is quite bad written. Maybe the tutor is looking for something like using a 100% duty cycle puls to activate the coil. Then changing to a lower duty cycle or lower input voltage for the long term operation. But as the question is written. This option are not allowed. Talk about "catch 22" question. Please post the solution given by your teacher. I am quite interested to know
30,813
As most have pointed out, you have a component that requires a certain current to operate, but this current causes the component to overheat.
Bottom line is a design flaw.
It is like designing an Induction heater coil and not running cooling liquid through the coil, without it the coil melts!
33,206
I disagree:
But in his next post he added, "The nature and purpose of the coil are not stated. Just need a method to keep the coil saturated at 5A while reducing the risk of damage to the resistor."
Very poor question (though perhaps the context of the surrounding material makes it make sense).
We need to know what the variables are that we can control in order to achieve this.
Brownout
Joined Jan 10, 2012
2,390
The timer does keep the coil saturated, until just before it burns up. If that solution isn't adequate, then the OP can clear up the requriements.
