Clock Signal in Micro controller
electronicsLearner77
Joined May 26, 2012
127
There is a clock signal in the micro controller.
Does the micro controller execute the instructions at the rising edge of the clock?
What is the significance of the duration of high and low time duration of the clock signal?
Why some instructions take only one cycle and others more.
One clock signal also involves the width of the clock signal?
Please advise.
Moderators note : placed questions on seperate lines
Picbuster
Joined Dec 2, 2013
1,062
There is a clock signal in the micro controller. Does the micro controller execute the instructions at the rising edge of the clock? What is the significance of the duration of high and low time duration of the clock signal? Why some instructions take only one cycle and others more. One clock signal also involves the width of the clock signal? Please advise.
Pick a simple micro controller manual like the pic12f series.
After reading take an other mpu like Intel or Motorola and compare you will find some differences.
Don't get me wrong but your question is comparable to 'what type of engine is in a motorcar'?
Picbuster
danadak
Joined Mar 10, 2018
4,057
There is a clock signal in the micro controller. 1) Does the micro controller execute the instructions at the rising edge of the clock? 2) What is the significance of the duration of high and low time duration of the clock signal? 3) Why some instructions take only one cycle and others more. 4) One clock signal also involves the width of the clock signal?
1) Depends on part, in general both edges used and pipelined parts can present with cycle skipping.
2) Basically mins in clock width controlled by propagation delays and on chip parasitic Capacitance.
Setup and hold time of clocked elements like flip flops, registers......
3) Depends on architecture, in general operations that require multiple memory accesses or
ones that test flags......
4) Not sure what question is, restate it another way.
Regards, Dana.
BobaMosfet
Joined Jul 1, 2009
2,211
Their question is simply how does a processor use a square-wave to perform things. Even just instructions.
The answer is obvious- a square-wave is the lowest common denominator of 'state change' over time. (yes/no aka 1/0 but with a time factor added) Without which you cannot take steps to perform actions, or do them in uniform time-frames (regular clock cycle versus irregular). You can use leading edge, trailing edge, or both depending on need so long as it's done uniformly.
dl324
Joined Mar 30, 2015
18,453
No. They can execute on both edges and there are some "paths" that could be multi-cycle (cycles of the clock).
AFAIK, the duty cycle is close to 50%. It gives you more margin against clock jitter, setup/hold times, etc.
It depends on the architecture.
The width of the clock cycle is determined by operating frequency.
