Setting up SPI in master mode on 16LF18324 calculating clock time and high signal
sairfan1
Joined May 24, 2012
107
I'm setting up hardware SPI as master on PIC MCU please refer to datasheet link at the bottom
Page 359 says we can configure SPI1CON1 register bits SSPM<3:0> for some choices, where I choose value 0010 that is for SPI acting as Master with clock Fosc/64, I'm using MCU internal OSC at 4Mhz that means 4,000,000/64 = 62,500 should I expect 62,500 cycles/sec (SPI clock signals) at SCK pin?
My 2nd question is what max voltage I can expect on SCK while I'm running MCU at 3.3v, I was not able to find any reference to this on datasheet.
Datasheet 16LF18324
Irving
Joined Jan 30, 2016
5,195
That appears to be correct.
Datasheet 16LF18324
If not otherwise spec'd, assume normal i/o pin spec. ie minimum of VDD-0.7v @ 6mA
sairfan1
Joined May 24, 2012
107
I'm looking to learn one more think based on above question, as we calculated speed 62,500/sec. is it possible that we can estimate clock (signal) time high, and clock time low from the SPI speed?
Irving
Joined Jan 30, 2016
5,195
I don't think so. I suspect its a square wave.
