I'm working on a circuit that uses an MCU and I've run out of I/O pins. I'm therefore trying to multiplex candidate signals in order to make the circuit conform to the maximum pinout limitation.
Here's exactly what I want:
The simplest circuit I've found so far that does what I want is a little too complicated for my taste. This because I'm thinking that the only way for it to work with zero current draw while in the idle state would be to use an impractical amount of discrete components:
Any suggestions?
- I need a circuit that will redirect a clock output (working voltage 3.3VDC) to either Out1 or Out2 depending on the state of CS.
- The circuit in question must draw zero, zilch, nada current when in the idle state.
Any suggestions?
