Influences of the Clock signal on the DAC output
Cosmin Traicu
Joined Jan 6, 2017
12
Hello, using the following circuit I am trying to drive a MOS transistor.
I shielded the output of the DAC, but the improvement is not enough. Is somehow the GROUND signal affected ? (the Arduino GND signal is connected to the GND of the whole system)
How can I filter the output of the DAC without changing the slew-rate ? Thanks !
