Oscillator output clock has less peak to peak
to PVR
Joined Jan 5, 2024
we are using oscillator AX3DAF1-156.2500T -156.25MHZ(LVDS), we are given 3.3V VCC, enable and Resistor termination with 100 ohms, output clock has less than 200mV PK-PK. and offsetting to 3.3V amplitude.
BobTPH
Joined Jun 5, 2013
11,643
datasheet?
What current is the device specified to source and sink? A 100Ω resistor would pull 33mA. Is that within spec?
WBahn
Joined Mar 31, 2012
33,154
Your 200 mV is a little low, but not terribly so. I don't know what you mean by "offsetting to 3.3 V", but if the common-mode value of the output is that high, then it is probably starving the current source in the part. How are you measuring the signal?
Also, you might put additional bypass capacitors on the supply, perhaps 1 uF and 10 nF, given the frequency you are operating at.
Lo_volt
Joined Apr 3, 2014
373
How's your bandwidth on your oscilloscope? Is it possible that the scope can't handle frequencies that high? If that were the case, it would show up as a heavily attenuated signal.
28,212
What is the reason for that 100ohm resistor connected across the output?? THAT is certainly causing the low output voltage. Remove the 100 ohm resistor and the output voltage will probably be in spec.
Reloadron
Joined Jan 15, 2015
7,931
This is the data sheet(s).
This is a test circuit example:
Used on the LVDS differential output test. I am not sure exactly which version the thread starter has. I assume based on the image posted by thread starter it's the differential output flavor I posted above with the 100 ohm resistor across the output.
Ron
28,212
I suggest remove the resistor and see what they have. To develop 3.3 volts across 100 ohms will take 33 milliamps if V=IR
Most clock modules do not deliver that much current, do they???
Reloadron
Joined Jan 15, 2015
7,931
None I am aware of? Just looking at the data sheet and saw their test setups. I also have no idea how the thread starter is measuring?
Ron
michael8
Joined Jan 11, 2015
472
What are you expecting? The LVDS output swing minimum spec from the data sheet is 250 mV.
Also what are you connecting to measure the value. 10 pF is about 100 ohms at 156 Mhz. You would need
a differential input to measure it. I'd guess that AC grounding one side might cut the output swing in half.
28,212
I am wondering if that differential output is isiolated from the source that they are using to offset the output. And I am thinking that the "100 ohms" is the impedance of the link to whatever the load would be. I learned about the low value load resistors many years ago, overheating an LM733. The fact that it can drive a 75 ohm video input does not mean that it can drive a 75 ohm resistor.
