Clock frequency divider circuit
Huzaifa Asif
Joined Mar 22, 2015
11
In order to create a divide-by-two circuit, we only use an inverter that is connected between the output and the input of a flip flop.
What if we want to create a divide-by-six circuit? Cant we use an inverter for that?
Regards
Alec_t
Joined Sep 17, 2013
14,330
A pity you didn't say that in your original post :(. This is clearly a Homework problem. You need to state exactly, in full, the conditions imposed on you.
Huzaifa Asif
Joined Mar 22, 2015
11
Sorry about that however I did mention about flip flops in my question but didn't explicitly stated that we are permitted to use flip flops only.
That's the only condition that's imposed on me.
absf
Joined Dec 29, 2010
1,968
Regards
Look at page 4 of the datasheet attached.
Allen
Huzaifa Asif
Joined Mar 22, 2015
11
Allen
Is D-flip flop different from J-k flip flop? I couldn't understand how it's working.
Check the third figure where three flip flops are being used with each dividing the clock frequency by its half. I want to make a similar circuit but it's able to divide the clock frequency by six (1/6).
http://www.electronics-tutorials.ws/counter/count_1.html
absf
Joined Dec 29, 2010
1,968
OK, I use 3x JK flip flop and connected them as T-flip flips as in your link. Then I add a NAND gate to reset the flip flops when it counts to 6 (see circuit attached). So it would be counting from 0 to 5 (i.e. Mod 6).
Are you able to do it with 3x D-flip flops?
Allen
Huzaifa Asif
Joined Mar 22, 2015
11
Allen
I haven't studied JK flip flops so I can't really understand. I shall be grateful if you can tell me how it works using D-flip flops
Alec_t
Joined Sep 17, 2013
14,330
In algebra yes; but simply ANDing the outputs of two cascaded flip-flops will give a pulse period 1/4 the input clock pulse period, with a 1:3 mark/space ratio . You need AND logic to detect a count of 6 and then immediately reset the count to zero.
