Clipping on CE ampflifier
ericgibbs
Joined Jan 29, 2010
21,622
hi jc,
I have downloaded your as file, I will run it.
E
This is what an AC analysis shows, a very poor response.
Edit:
You should not try to drive an 8R load with that amplifier.
Ian0
Joined Aug 7, 2020
13,306
You need to use a sensible load resistance, at least ten times the output impedance of the amplifier.
The output resistance is of the order of 1300Ω, so perhaps if you change the load resistance to 13k you might get somewhere.
jclfc
Joined Oct 21, 2022
9
Thanks for reviewing. If you look at my workings that I have posted it shows I have been given some set parameters - including the load resistance (and capacitors which is not showing on my workings) - and I have calculated all other remaining ones needed to construct the CE amp. The calculated and simulation results using 1mV input are very close which seems to suggest my workings are correct. We have been advised to raise the input to 100mV to show distortion and explain why it happens. I'm struggling to see why it works as designed at 1mV and not at 100mV
Ian0
Joined Aug 7, 2020
13,306
Should this thread be in homework help?
. . .but you need to examine what limits the maximum output of the amplifier, and if you try some other values for the load resistance you will see.
jclfc
Joined Oct 21, 2022
9
hi jc,
E
Edit:
Thanks for reviewing. The resistor load has been set by the lecturer. My workings seem to suggest the system works as designed at 1mV but not at 100mV input. I appreciate the load resistance isn't what this type of design will work best with, I think I tackle that latter on. But I have been asked to explain
Oh sorry for posting in wrong area. I'll take your advice :)
ericgibbs
Joined Jan 29, 2010
21,622
hi jc,
I would suggest you calculate the output impedance of the Collector and the impedance of the 8R load.
E
BTW: a hint, when you use AC analysis set AC at 1v not 0.1v.
Using a 1v AC gives direct 'db' readings on your LTS plots.
ericgibbs
Joined Jan 29, 2010
21,622
As you know, we can only give hints and guidance for Homework questions.
Post your calculations and we can check your work.
E
35,270
I will repeat what has already been stated in posts #5 and #6 in order to drive home a point.
You have an impedance mismatch.
Ideally, the driver impedance should be lower than that of the load, 10 times lower.
If the driver impedance is 1300Ω then it would be capable of driving a 13000Ω load.
If your load has to be 8Ω then the driver impedance should be less than 1Ω,
You have the wrong circuit to achieve this.
jclfc
Joined Oct 21, 2022
9
Thanks for reviewing. I get the point that's been driven home! :)
ericgibbs
Joined Jan 29, 2010
21,622
hi jc,
You can use LTS to plot the Input and Output impedance values.
E
Edit: @jclfc
I have seen your calc's OK, so now that you have calculated Zout, this is what LTS shows.
E
38,911
Basically the output can drive only some much current into the load, so 1mV is ok, but 100mV saturates the output drive since it can't deliver the needed current.
The positive output current is provided by RC, so how large a voltage can be generated at the output load by this value of RC?
Ian0
Joined Aug 7, 2020
13,306
Work out how much current you need through the 8Ω resistor to get the output voltage you want.
Then you need to realise that, on the positive half cycle, ALL that current has to come through your 1.3k resistor.
WBahn
Joined Mar 31, 2012
33,309
Hi
I'm trying to understand the positive half clipping that occurs when I change the input signal from 1mV to 100mV. I've read up on distortion from https://www.electronics-tutorials.ws/amplifier/amp_4.html but it doesn't seem to suggest my problem (unless my ignorance is shining through).
Below is the 1mV simulation followed by the 100mV.
Thanks in advance.
Let's assume, for the moment, that your capacitors are all sized to place a 100 kHz signal in the passband (I'm pretty suspicious of this, but we'll assume that for now).
That means that your bias voltage across the emitter resistor is about 2V and your voltage drop across the collector resistor is about 4 V. If the CE capacitor is doing its job, that means you small-signal gain is about 4 V / 26 mV or about 160.
That means that any signal into the base more than 4 V / 160 = 40 mV is going to require that the transistor go into cutoff.
The output has a cutoff frequency dominated by the 8 Ω resistor, so that's about 200 kHz, which means you are operating well outside the pass band.
Look at your collector voltage and see how close to 12 V it is getting.
Now let's consider those cutoff frequencies.
You emitter bias current is going to be about 3 mA, which makes re about 9 Ω, which makes the small signal input resistance about 900 Ω. That will dominate the resistance seen by the input. Combined with a 0.1 uF cap, the cutoff frequency is aout 2 kHz, so that's okay.
The emitter bypass cap has a cutoff of around 25 Hz, so that's good.
The input capacitor is going to see something around
WBahn
Joined Mar 31, 2012
33,309
Everyone seems to be laser focused on the load impedance. While this explains why he is getting no gain out of the circuit, it does not explain the clipping that he is seeing.
It's my belief that if you remove the load entirely you will still see the clipping because it is due to the amplifier being overdriven by a 100 mV input signal.
Also, a signal of 100 mV is considerably larger than the thermal voltage, which you should stay below if you want the small-signal model to remain reasonably linear.
