Class D amplifier books/projects
iliev986
Joined Oct 29, 2020
20
Hello colleagues,
First I hope to write in the right section of the forum.
Thus, I am particularly interested in the study of Class D amplifiers in particular. I would be happy if you could share all sorts of materials on this subject, be it books (design manuals) or other sources of such practical electrical circuits.
Thanks in advance!
Greetings!:)
38,513
This one is interesting as it uses the phase-shift in the feedback loop to make the pWm frequency.
Looks like a really simple design with good performance.
Unfortunately, for whatever reason, they didn't give component or supply voltage values for their circuit measurements.
Ian0
Joined Aug 7, 2020
13,132
Yes - that would have been nice - but if I were going to build it, I'd probably use a half-bridge driver IC, which have improved a lot in the 15 years since the paper was published, and I suspect that performance depends a lot on the MOSFET drivers.
iliev986
Joined Oct 29, 2020
20
Thank you very much for the submitted materials. My goal is to be able to assemble several electrical schematics, to understand their principle of operation, to weed out advantages and disadvantages over other classes and to work on possible improvements.
Jony130
Joined Feb 17, 2009
5,598
Thanks for posting UM10155 - that's the circuit diagram that belongs to the paper in Post #4.
WITH COMPONENT VALUES!
Exactly, Bruno Putzeys the inventor of a "UCD topology" was working in Philips (NXP).
What is the correct arrangement of the photos, because I was a little confused? The images are too big
Can you elaborate a bit more on what exactly is your problem with the photos?
iliev986
Joined Oct 29, 2020
20
Is there any information on how to calculate (choose) transistors in a class D amplifier circuit?
Thanks!
Ian0
Joined Aug 7, 2020
13,132
Thanks!
If you look at the Infineon website, they have some that are designed specially for class-D audio.
Because the dead-time affects the performance, low dead time is important, and consequently, a device with low gate charge is required.
