class d amp mosfet heating
franticAAC
Joined Jun 25, 2012
30
i'm designing and realizing on prototypal board the class d amplifier in figure below
the problem is that the Infineon MOSFETS become too hot beyond the calculations that I made, also without load and with lower voltage than i need. Also they present 100ns of miller plateau at which the measured current on high side mosfet drain is of any amperes.
I test many mosfets and they all have the same problem maybe less pronounced.
The only one that doesn't have that kind of dissipation issue is International Rectifier mosfet in figure.
What do you think? Is it a bad driving or parasitic components of other mosfets?
I'm looking for a mosfet with lower Rds in order to increase output power...
Could you help me?
Thanks
38,678
I'm trying to determine what the two signals look like that are driving the top and bottom MOSFETs in the bridge.
Where does the deadtime occur?
38,678
Okay. I'm trying to determine if the deadtime delays are being done correctly, i.e. does the top transistor always turn OFF before the bottom transistor turns ON, and does the bottom transistor always turn OFF before the top transistor turns ON.
MikeML
5,444
Okay. I'm try to determine if the deadtime delays are being done correctly, i.e. does the top transistor always turn OFF before the bottom transistor turns ON, and does the bottom transistor always turn OFF before the top transistor turns ON.
Especially considering the FET turn off delay as shown in the sim I linked to...
