CK722 transistor equiv ?
xtal_01
Joined May 1, 2016
227
This came up a few days ago in my feed. I remember seeing it as a kit but forgot about it. I though it might be interesting to take a shot at it.
Question ... what transistor would you use?
It says CK722 .... rare ... Very Expensive
I did a quick search and a replacement would be 2N107 ... also rare and Very Expensive
I did more searching and got a lot of "might be equiv".
I don't have a transistor replacement book
What is a modern (cheap) equivalent to this transistor?
Thanks!
xtal_01
Joined May 1, 2016
227
It's a germanium RF transistor. Try GT308, unless the guitarists have bought them all.
By the way, be careful with that asbestos cement!
It is funny seeing the asbestos cement. I don't even think you can purchase it anymore ... not that I would. I am sure there is some kind alternative.
Interesting ... I see this is a Soviet transistor .... ebay lists many from the Ukranine and even with shipping they are relatively cheap. Thanks!
Ian0
Joined Aug 7, 2020
13,310
You can get fire cement for sealing joins in flues for stoves. I wonder if that would be similar.
I’m sure that at the moment the Ukrainians would much rather have dollars in their bank accounts than a shed full of old transistors.
xtal_01
Joined May 1, 2016
227
We are on the same wavelength! I was going to out to the workshop and see if I still had some joint compound that I used a few years ago to help a friend seal a flue where it exited his garage (sealed around cement blocks). It was brittle but maybe I could add some fiberglass to it so it was a bit less brittle (not that I am going to drop kick this).
Yes, here in America, the war doesn't even make the news anymore ... sad.
Thanks again!
