circular polarized patch antenna multi resonances logic
yef smith
Joined Aug 2, 2020
1,486
Hello,In microstrip antenna with circular polarization we have a situation where we have multiple resonances depending on the frequency as shown bellow.
Is there some detailed explanation explanation on how those resonances are formed?
and why we have 90 degree phase in the interpsection point between the hills?
Thanks.
Tesla23
Joined May 10, 2009
560
The patch isn't square and so there are two modes that are close to resonance. For CP we want the radiated fields 90 deg apart. Why don't you try to work out from the location of the feedpoint, and the fact that the patch isn't square, what the phase difference between the two modes is?
yef smith
Joined Aug 2, 2020
1,486
Hello Tesla23, I have tried to implement your words into actual CST simulation.
As you can see bellow the is a coaxial cable which acts for pin feeding as shown bellow.
on the coaxial pin feeding i have defined waveguide port as shown bellow.
then i looked at the far field plot of each electric field mode as you can see bellow.
The field lines of the modes are not perpandical to each other as shown bellow.
Also CST says that these are TEM modes instead of TM for some reason.
also i tried to look at the Z-parameter plots.where i was supposed to see the two hills from the manual with the intersecting point,i only saw one hill.
Where did i go wrong?
Why my modes are not perpandicaluar to each other?
Thanks.
Tesla23
Joined May 10, 2009
560
Then read them again, and your initial post. Also, whatever happened to analysis, rather than just plugging stuff into CST?
If you can't figure it out, here's a good reference:
W. Richards and Y. Lo, "Design and theory of circularly polarized microstrip antennas," 1979 Antennas and Propagation Society International Symposium, 1979, pp. 117-120
yef smith
Joined Aug 2, 2020
1,486
Hello Tesla 23,I have taken a working CP patch antenna with trimmed edges as shown bellow.
The Axial ratio plot is as shown bellow also the rotation of far field plot.
The feeding is not in diagonal but in the middle.
I have tried to analyze this model using the formula taken from the article you reccomended using the measures of the model shown bellow.
Using the matlab code shown bellow i got only 1.5 degree phase shift(not radians)
also my Z11 doent have 90 phase in f=2.3314Ghz
So why Its workig , Where did i go wrong with implementing this formulla or understanding the Z11 data?
Thanks.
7.06/sqrt(2)=5
a=42.56;
a_t=37.56;
k2=2*(a-a_t)/(pi*a);
cof=pi*(a-a_t)/a;
phase_diff=k2*sin(cof);
phase_diff_deg=(180*k2*sin(cof))/pi;
1.5459
