Circuit or arduino?
MisterBill2
Joined Jan 23, 2018
28,450
Hey Max! I have two ignitron tubes that were used to switch some spot welders. I doubt that they were faster than relays, based on the amount of mercury that they had to evaporate to switch on. Of course I never saw the trigger portion of the system. They are water cooled, with fair sized water lines. Just another useless bit of information.
30,857
Yes, I worked with many of those, they were used for precise No of cycles when switching, generally fired by a thyratron. and had water cooled jackets.
They were also used for seam welding for e.g two halves of a automotive gas tank, the electrodes were rotating copper wheels and the ignitrons fired in bursts as the copper electrode wheels moved the tank flange through!
.Another method of firing them was a from a decatron tube counter.
1950/60 technology!
30,857
You could look at a 555 monostable trigger mode!
Adapting the Triac circuit in Fairchild app not AN3006. but using the zero crossing series of Triac.
You could closely operate the time on with required number of cycles.
Of course this could be quite a trivial for a small 8pin PicMicro !;)
Rufinus
Joined Apr 29, 2020
325
Thabk for your advise. But I already installed a standar spotwerder control. Of course your proposal is better, I always heard about cycles in spotwelding, but for my porpuse, I think this circuit will done
MisterBill2
Joined Jan 23, 2018
28,450
The operation being a spotwelder is certainly very different from the very limited bit of information in the first posting. At that point I see that the TS had already decided where the problem was.
Rufinus
Joined Apr 29, 2020
325
Sorry, maybe I didn´t explain myself properly, I don´t really speak english very well.
I wanted to make a DIY spotwelder based on a modified microwave oven transformer. At the beginning I only need one automation so since it was simple, I thought a simple timer was enough, but maybe I could use arduino. But as I was advancing in the project I realised I need more steps, so in the end I decided to do it with arduino, because I don´t have enough electronics knowledge and I was to be here asking every component and everything.
MisterBill2
Joined Jan 23, 2018
28,450
OK, so the goal is a semi-automatic spot welder machine. With using a reworked microwave oven transformer it will probably not deliver more than 800 watts to weld with. That will work for welding solder tabs onto batteries, a very useful function.
30,857
Based on post #29, that it uses a reworked microwave transformer, I seriously doubt this welder will be used in actual production.
....Although it might be capable with the right adaptation, it mirrors the suspended hand operated versions exactly!
This one is hand pressure lever operated.
