MaxHeadRoom
- Joined Jul 18, 2013
- 30,884
@SaraB2026 A minor point, you might also mention to your professor he is most likely guilty of a common mistake, using the wrong power common signal, i.e. using Earth GND instead of signal ground.
She added clarification in post #4; which was about 15 posts before yours.I can, of course, only comment on what the assignment (clearly stated 'the assignment is as follows' at the bottom of the schematic) indicated.
SaraB2026 – Refer to post #7 where WBahn had an excellent suggestion of simply drawing a box around each component. Everything else is wire. Once you realize that, making a breadboard of the circuit should be fairly simple.I am having trouble putting the circuit onto a breadboard. I just cannot picture at all how the schematic is supposed to translate to real life. I don’t really understand the how to use the socket or the relay.
