circuit below what is purpose of r5?
WBahn
Joined Mar 31, 2012
33,349
I understand what hysteresis is ok from this forum. I just cant do calculations and equations to measure hysteresis and what voltage and currents go where due to complexity of the circuit itself.
Calculating the hysteresis requires a more detailed look at the circuit than can be gleaned from a simple model like I used to provide a qualitative description.
I would recommend looking at the small-signal model of the circuit. That may let you see how to come at the hysteresis calculation, but maybe not. I'd have to do it to convince myself one way or the other and I just don't have the time right now.
28,605
I did not do any math to see the positive feedback that makes it non-linear, so that it tends to jump. The detailed math is indeed a bit tricky.
be80be
Joined Jul 5, 2008
2,400
GW PSLM32.UL is a 100mA led that would be 60 ohm but that is not going to act anything like a 60 ohm load the OP should add a resistor before the led like 24 ohm 1/4 watt
R = V / I = 6V / 0.1A = 60Ω
P = V×I = 6V×0.1A = 0.6W
28,605
Evidently the actual circuit works quite well, but the simulator has no LED model. A substitute in the simulation would be three 1N4000 diodes in series.
sghioto
Joined Dec 31, 2017
8,763
Don't need the LED in the sim.
The LED is 3 volts at 100ma = 30 ohms.
The supply is 6 volts hence the LED is represented by a 60 ohm resistor.
28,605
OK, that is not the type of LED I was thinking about. BUT my suggestion of three power diodes in series will be a fair substitute. In addition, that is not the part of the circuit that the question is about.
hhsting
Joined Apr 25, 2024
395
Out of all resistors in post #1 circuit, what would be the worst case power of resistor in watts i would need to buy in post #1 circuit?
hhsting
Joined Apr 25, 2024
395
Has anyone actually constructed the circuit post #1 real life? I did and I am getting Q1 vbe of 1.0A with 0.66V. The V2 is 0.1vdc. My led light wont turn on.
sghioto
Joined Dec 31, 2017
8,763
Yes I have. It works as designed.
The LED should only come on if the voltage on the base of Q1 is below appx .6 volts.
