Cheap DC To AC Inverter Circuit Using Power Transistor
q12x
Joined Sep 25, 2015
2,245
(just curious)
- How reliable is this?
- If not very reliable? how can it be improved?
- Is this like the basic circuit? I have the impression it is. I'm not really into this category of electronics, so it's my first, but i also have the impression that those 2 transistors and their resistors are forming an oscilator, a very weird one but very simple, also using the coil from the transformer i might guess. Feel free to chop my head if im wrong. Classically, I imagined this kind of circuit having a bistabil flip-flop in the secondary of the transformer, but this circuit is bluntly more simple that my imagination. Thats why im so perplexed. I will try build it sometime but before doing that i need to know if its even a correct one, from you.
Thank you as always, you are the best.
Video link here: (scroll fast through the video, made by some indian, but to get the idea)
This MJE13007 power transistor pdf here : https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwiCzbKEoLHtAhU5i8MKHeLNAF0QFjAAegQIAxAC&url=https://www.onsemi.com/pub/Collateral/MJE13007-D.PDF&usg=AOvVaw2plLabh3AvG5-aSTZbgtOB
Alec_t
Joined Sep 17, 2013
15,158
Not very. The transistors will be damaged because their bases are driven negative far below their Veb breakdown point. Respective diodes in series with the bases could prevent that.
Imbalance in the circuit could result in net DC current in the transformer windings and consequent core heating.
If the circuit fails to oscillate (it's a relaxation oscillator) there could be excessive heat developed in one of the transistors and a transformer winding.
The properties of the transformer are important to the performance/efficiency of the circuit.
There will be horrendous EMI generated.
Sensacell
Joined Jun 19, 2012
3,789
As with most stuff electronic, the really simple circuits seem appealing to beginners but are actually very tricky and don't work well.
Look inside a commercial inverter, you will see a lot of parts!! They are there for a reason.
When I was starting out in electronics, I was always attracted to those simple-looking projects, but quite often they were very frustrating- they just didn't work.
Once I overcame my fear of complexity, I realized complex circuits are easier to get working- because they are made of BLOCKS that can be analyzed and understood separately.
You could learn some stuff by building this thing, but it's a terrible design if you want a real inverter that actually works driving useful loads.
28,412
certainly posts 2,3,and 4 are all correct, although I am not familiar with that name for the oscillator. The circuit s lacking all of the additional components that are added to provide stability and protection, and would probably damage the power supply of any PC connected to it. In addition it is probably very dependent on having exactly the right load and the right transformer in order to even work. The name assigned to this style of circuit assigned by another group would be a "blooper" oscillator, meaning some collection of parts that happens to work sometimes, under certain conditions. It functions because the Motorola MJ13007 is a fairly rugged device.
DickCappels
Joined Aug 21, 2008
10,661
The MJE13007 was designed for AC Line powered inverters and not reliable with a lot of collector current, also this trick of driving a transformer "backwards", that is driving what was intended to be the secondary as the primary keeps the output voltage from getting to what may be the expected value because the intended secondary was not designed to drive the magnetizing current of the transformer, which might approach 50% of the load current. This is because an IR drop because of the magnetizing current in the secondary was not planned for.
One little thing, if you are going to power something from a device that can supply substantial current, like a car battery, use a fuse or you may wind up with a charred circuit or much worse.
38,857
Also the oscillating frequency of that circuit is determined by the transformer saturation characteristics and likely will be significantly different than the normal 50/60 Hz main's frequency.
Typically that circuit is used to generate DC at the output by rectifying the signal, not to generate AC.
q12x
Joined Sep 25, 2015
2,245
It's a basic Royer Oscillator without diode protection for bemf spikes ..
- WOW. Fantastic reading ! https://en.wikipedia.org/wiki/Royer_oscillator
- Thank you very much for this information !
I can't say i understood All there is there explained, but i have a better idea now after reading it. It is indeed a very specific and dedicated circuit. They also say "... which has been extended recently to drive low voltage LED lamps too".
- I know there are tens of models of transformers these days, and for sure I have no clue which is which, especially after their names. I only have a very general, basic idea about inductors and transformers. Not in depth for sure. In this page about Royer oscillator, is mentioned very clearly that all this circuit needs a "saturable-core transformer", and i have no idea what is that. MY basic transformer that i know for decades, is that one with a iron/steel core made from sheets cut as E and I or U and I and assembled stacked and glued. I think in my young wild life, I think I may even constructed such a transformer all by hand, and i know for sure to run from building another one, because ... its hard as hell. These are step (up or down) only transformers I put my hands on and had experience directly. I also played with some I core (also steel but then replaced exclusively by the ferite core) transformers, but i didnt find anything practical to use them, because they involved too much complicated electronics so i give up in playing with those.
- Back to the saturable core transformer, which is a very important component for this thing to work, also named as "saturable reactor", from the reading i just did, I searched over the internet to actually see how it looks like. I was disapointed to not find anything very clarifying, but i get over this diagram
(though im not sure i find the right one, but i have a broader idea about this subject, now). Why i searched for its physical look, because i wanted to see if its the same with the one from the indian movie. I dont think the indian used a correct transformer even if it worked for him. As @MisterBill2 here said, its a "[ ..."blooper" oscillator, meaning some collection of parts that happens to work sometimes, under certain condition ]". So its how i think about the indian circuit as well, as a blooper. But it works and i like it, even if its a blooper.
Very fascinating subject indeed.
Thank you very much so far.
Alec_t
Joined Sep 17, 2013
15,158
Given enough current through the coils, the core of any transformer will saturate. The transformer in the vid is nothing out of the ordinary.
28,412
The circuit shown in post #8 is a magnetic amplifier, a device used for power control long before transistors were discovered or invented. It uses magnetic saturation of a core to vary the impedance of an inductor used to control AC current through a load. Although the range was limited it served the purpose adequately at the time.
The saturation of transformers in inverter circuits is presently not used, at one time some inverters used a separate transformer that would saturate as the feedback source, and a non-saturating transformer as the power delivery device.
The challenge posed by core saturation is that suddenly the impedance drops, the output voltage stops rising, and the current may spike. So there is a great deal of waveform distortion when that happens.
There is a huge amount of literature and information about inverters that was created back in the later sixties and early seventies, so continued research will be educational. But avoid yootoob postings, they will not help much.
It's sort of interesting that magnetic (miniaturized high-frequency) amplifiers are making a comeback in switching power supplies for output regulation. I worked on old military gear that used them in the 70's.
https://www.toshiba-tmat.co.jp/pdf/en/product/3-1_am_parts_mtmse.pdf
https://www.dextermag.com/wp-content/uploads/2017/03/Toshiba_Designing_A_Mag-amp.pdf
DickCappels
Joined Aug 21, 2008
10,661
Magnetic amplifiers were making a comeback in power supply at least in the 1980's, as I recall, for post regulation.
These were used in conjunction with popular switching power chips
BobTPH
Joined Jun 5, 2013
11,661
I'm trying to create a new inverter circuit, so I have to know about this..
What do you hope to accomplish by that?
Decent inverters today use digital (PWM) methods to create a pure sine wave that is near theoretical maximums in stability, frequency accuracy, and efficiency. What is it you think you might improve upon?
28,412
Most designs include a trade-off between cost, efficiency, and performance. Design effort and time are in that mix as part of "cost". so please let us know what area you are wanting to improve.
Like Bob stated, sine wave inverters, at least some of them, are very good,
For many applications that level of purity for the sine wave is not needed, and so much less expensive inverters are quite adequate, as well as more efficient. And for producing a DC output, inverter based supplies can be either cheaper still or even more efficient.
So it will educate us and allow for well thought out useful suggestions to describe what aspect you intend to improve.
schmitt trigger
Joined Jul 12, 2010
2,255
All magnetic cores do saturate. But what is meant by saturable core, is a one constructed with a magnetic material that saturates suddenly... what is called a square-loop material. And yes, this material was also used on magnetic amplifiers.
This sudden core saturation is absolutely required for a fast switching waveform. You want the switching transistors to quickly switch between on and off states. Anything in between, the linear region, are pure losses.
For a magnetic material to be considered square loop, the ratio between Remanence (Br) and saturation (Bs) must be higher than 0.85
Common steel cores have soft saturation, which means that both the transistor and the transformer will heat up significantly and very little output power will be produced in relation to the input power being drawn.
schmitt trigger
Joined Jul 12, 2010
2,255
All in all, this Youtube video shows the power of media to disseminate incomplete information. Not totally false, but very incomplete, leaving out very important details.
These videos do not even attempt for a minimal understanding of the topic being explained. I could bet 100 Rupees that if I asked the person which posted the video to explain its principles of operation, he would not be able to do it.
28,412
Most magnetic cores CAN saturate,, but many designs take a lot of effort to avoid it. That is why the better HIFI amplifiers had such massive output transformers, which was to assure that they would not come close to saturation and that form of distortion.
And certainly the explanations on "the cartoon channel" YouTube) of how things work is really poor, which is what I would expect.
And it has not yet been mentioned, but the early sine wave inverters were a whole lot like the early low distortion amplifiers, and with tube circuits the efficiency seldom reached 50% overall. Low distortion implies linear operation, which is the least efficient mode. The best current technology schemes use pulse width control to form a sine wave, with only switching losses to contend with, so the efficiency is better, But there is a fair cost because the precise fast switching is not trivial to produce.
