Charge pump
Drmario5237
Joined Oct 14, 2018
65
If you have varible voltages as input voltage such as voltage from a rf signal because distance from transmission changes thus the amount of watts the receiving antenna will pick up will a charge pump not only increase output voltage but will it take varible input voltages ( any voltage that differs over distance) and make it one constant voltage. Thanks.
dendad
Joined Feb 20, 2016
4,641
What are you actually wanting to do?
Are you trying to transmit power? that only works over VERY short distances.
Some more info is needed, like what power levels do you need....
AlbertHall
Joined Jun 4, 2014
12,640
Is there anything that will do that
Many RF receivers have some form of AGC (automatic gain control). AM receivers commonly use a diode demodulator and the rectified voltage is fed back to reduce the gain of the IF stages to keep a more stable received signal. FM receivers let the received signal clip and that stabilises the level.
Drmario5237
Joined Oct 14, 2018
65
does the automatic gain control have to have another input another voltage input 2 stabilize the voltage from the antenna or does it work with just the voltage from the antenna
