I want to charge a leisure battery from the alternator.
Things have changed over the years, so instead of simply connecting a wire from the alternator to a relay, now there is a DC to DC charger with a D+ or IGN wire input.
The IGN comes live when the ignition is switched on, so even though the engine isn't running, the main battery will charge the leisure battery.
What I want is a D+ wire. I've searched and can't find a proper answer.
NOTE: the later chargers are intelligent, and can be damaged if not looked after.
I would like to make a D+ wire from the 12V system, so a reliable circuit, that is connected to the IGN and monitors the raised voltage, then switches on the D+ wire (low current signal)
Any suggestions pleae?
C
C
