Changing Speeds on 8" Drill Press
nDever
Joined Jan 13, 2011
153
Hey Guys,
I'm back with my drill press from Harbor Freight. If you posted on my problem thread (http://forum.allaboutcircuits.com/threads/pcb-drilling-solutions.105969/), then you know that I bought this primarily for PCB hole drilling. It works great, and it was a perfect solution; I've made a few boards already!
My problem now is that I need to switch to a higher speed. The manual said that I needed to change the position of the drive belt, but it's significantly tight and I don't want to break it. Does anyone who has this drill know what the problem is?
jpanhalt
Joined Jan 18, 2008
11,087
There should be a way to loosen the motor mounting rods and slide the motor to the front. It looks like there may be a lock on the RH side. From the design, there may be a lock on both sides. The belt does not have to be real tight. You also remove from the large pulley first. I went to "link belt" for my drill press (e.g.,http://www.zoro.com/i/G3722311/?utm...hopping_Feed&gclid=COjuuu6B78MCFYk8gQodFqQAig). It runs much smoother.
John
30,689
It looks almost identical to mine, there is a tensioner on the same side as the lid latch that removes the tension on the belt for changing.
You may want to look at a DC T.M. motor and simple controller and get rid of the belt nuisance, especially for light work such as electronics.
jpanhalt
Joined Jan 18, 2008
11,087
I switched to a 3φ motor and never regretted it. The DC or 3 phase work about the same in this application, but the 3 phase motor may be cheaper. Mine was a slightly bigger drill press, and the bigger 3 phase motor was quite inexpensive. Both will give soft start. The 3 phase will also give a little "overspeed;" whereas, there is nothing faster than 100% for the DC motor.
John
#12
Other options that might not be practical or even possible:
1) Increase the size of the pulley on the motor shaft
2) Buy a faster motor.
