Like what prime points in Celsius?Metric much easier to remember prime points,
It's a matter of context. Becoming extremely familiar with one system of units in a particular context does not mean that that system is ever going to feel familiar in another context.As an engineer/scientist who works in °C but lives in °F, those numbers feel so random.
I’d concur with that, you can measure the same parameter in two different situations in two different units, and if the two don’t interact then there’s no problem.Yes it is.
But in all my technical work I used the Celsius scale as all the tech requirements were in Celsius (expect for the thermostats in my office building, which were in Fahrenheit).
My use of Fahrenheit was/is for ambient room/outdoor temperature readings in a non-technical environment.
I suppose it could be considered a disadvantage to use both Fahrenheit and Celsius temperature scales, but I'm used to it.
...I think of Darth Vader.If I hear that someone is two meters tall...
two foot is just over 0.6m, six meters is 20ft (ish).But if someone tells me that a radio wave has a two foot wavelength, I have to convert that to "a little less than six meters" for it to have meaning to me.
"But I'm not as thunk as you drink I am."Policeman: “Step out of the vehicle, please.”
I'm from the UK. All my life I used C but was well aware of F and the respective definitions, all thermometers were dual scale. When I came here (as an adult) I had trouble mapping an F temp to a "feeling" and had to map F to C where it was easy. But after time that slowly changed. Now any weather temperature in C bewilders me just as F once did.I have a curiosity about using the Celsius temperature scale versus Fahrenheit.
I know the USA is likely considered somewhat backwards for still using the Fahrenheit temperature scale for non-technical uses, (most science/technical functions use Celsius) but I find the scale more relatable to human comfort for ambient temperature readings.
0°F is really cold and 100°F is uncomfortably hot with 70°F being in the comfortable indoor range.
And 1°F is a good adjustment increment for an indoor thermostat.
I would suppose you get used to the Celsius temperature values for those arbitrary comfort levels, but it seems less intuitive.
Also I believe Celsius home thermostats use 0.5°C setting increments as a 1°C jump is likely too coarse.
I'm interested in thoughts on this from those in the rest of the world who use Celsius for ambient temperature readings.
On a side note, I also find the gallon a handy unit for liquid measure such as gasoline and milk.
I could live with kilometers instead of miles though, even though the word has too many syllables.![]()
10m is 1 atmosphere. That one is easy to remember, as well as 3e+8 m/s = 1 ft./ns, and 330 m/s + ~0.5m/s/C (good enough for napkin calculations).two foot is just over 0.6m, six meters is 20ft (ish).
Hi W,I'm pretty sure I see his point and it's not unreasonable.
Just like Americans like the term 'soccer' while the rest of the world likes 'football', it is a matter primarily not of which term is better, but which term you grew up with, are exposed to more often, and use most often. We (Americans) like the Fehrenheit scale not because it has any particular advantage over Celsius, but because it is what we grew up with and what we think in terms of. When we point to its "conveniences" we are essentially cherry picking data points that we have grown accustomed to and emphasize those as being advantages. But the people that grew up with Celsius can (and do) the exact same thing.
Policeman: “Do you know how fast you were driving?”
Me: “My groundspeed was 78.2 knots with a heading of 2,3,oh, but as a had a tailwind my indicated airspeed was 65.17 knots which at this temperature and barometric pressure equals 0.0977 Mach. Or 1.118x10^-7 C. I wasn’t speeding.”
Seriously: my wife and I fight over 1 degree F on the thermostat every single night.It would be an interesting experiment -- and one that I'm sure has been done more than once -- to see how much of a temperature difference most people can really sense.
I admit that I do find that a bit surprising, particularly if either or both of you sleep under any kind of blanket.Seriously: my wife and I fight over 1 degree F on the thermostat every single night.
I set 70F before I go to bed. She changes it to 71. I have to get up 30 minutes later to drop it back down to 70. Then she complains that she is cold.
I swear on my life this is a daily occurrence.
Thank you. That's exactly what I tell her: if she's cold, put on an extra blanket.I admit that I do find that a bit surprising, particularly if either or both of you sleep under any kind of blanket.
You've just described the first 365 days of my married life ...Thank you. That's exactly what I tell her: if she's cold, put on an extra blanket.
When I'm hot, there is nothing I can do to make myself unhot but to lower the thermostat.
She says extra blankets are "too heavy". Princess and the Pea kinda stuff.
| M | Inductance values versus voltage? | Analog & Mixed-Signal Design | 3 | |
| J | Voltage versus Current | General Electronics Chat | 5 | |
CC versus CV: efficiency | Power Electronics | 11 |
