Hi, i'm learning about spice netlist recently and i've got a problem with linear dependent sources.
Here is my netlist source code.
Example 1 : DC Voltages of a linear Network
**Rangkaian**
*Sumber independen
Vs1 n1 0 1V
Vmeter n7 n2 0V
Vs2 n2 n3 6V
Is1 n6 n4 1.5A
*Sumber dependen
*Sumber dependen CCVS (Current Controlled-Voltage Source)
H1 n5 0 Vmeter 2
Vmeter n7 n2 0
*Sumber dependen VCCS (Voltage Controlled- Current Source)
G1 n4 0 n4 n3 4
*Elemen rangkaian
R1 n1 n7 1ohm
R2 n4 n3 3ohm
R3 n2 n5 2ohm
R4 n1 n6 5ohm
**Output**
.TRAN 1ms 50ms 0ms 1ms
.END
when i run it, there is a message says multiple instances of "Vmeter".
Any idea what's the problem?
I used spice second edition by sedra and roberts. It appears that there is the difference about dependent source syntax betweem LTSpice and sedra's book. I've searched the internet but i get nada. Thanks for ur help.
**Rangkaian**
*Sumber independen
Vs1 n1 0 1V
Vmeter n7 n2 0V
Vs2 n2 n3 6V
Is1 n6 n4 1.5A
*Sumber dependen
H1 n5 0 Vmeter 2
Vmeter n7 n2 0
G1 n4 0 n4 n3 4
*Elemen rangkaian
R1 n1 n7 1ohm
R2 n4 n3 3ohm
R3 n2 n5 2ohm
R4 n1 n6 5ohm
**Output**
.END
