CAR PUSH START CIRCUIT HELP
saintblues
Joined May 15, 2020
27
I am purchasing this kit https://www.aliexpress.com/item/32921546222.html?spm=a2g0o.detail.0.0.5c767fffO0SQYr&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.169870.0&scm_id=1007.13339.169870.0&scm-url=1007.13339.169870.0&pvid=f5f0e6cf-c3a2-4c09-82f8-be721241bf09&_t=gps-id:pcDetailBottomMoreThisSeller,scm-url:1007.13339.169870.0,pvid:f5f0e6cf-c3a2-4c09-82f8-be721241bf09,tpp_buckets:668#0#131923#18_668#888#3325#11_668#2846#8116#2002_668#2717#7558#101_668#1000022185#1000066058#0_668#3468#15609#236
I want to however replace the push start button this kit comes (labeled "original" in pics attached) to another style push start (labeled "p3" in attached pics). The issue I have is the "original" push start button connects to a 10 pin input on the control unit however the push button I want to use (the "p3") only has 4 wire connector. See pictures attach of the "original connect wire" and the 4 pin connector shown in the "p3" pic and the "p3 connect wire".
My question is would it be possible to get the p3 to work instead of the original switch it comes with?
I have also attached pictures of the "10 pin input" on the control unit as well as the "circuit diagram" of the 10 pins on the control unit which highlight wat each pin is used for.
I would really appreciate help in this. Thank you in advance
saintblues
Joined May 15, 2020
27
so if I use p3 it will be: 12V BROWN WIRE to both POSITIVE (+) input pins, 2 wires are empty (empty pins). BLUE WIRE into both BLUE LED pins, GREEN WIRE into RED LED pin, 1 GROUND WIRE into GROUND pin (which i will get externally as the switch does not have its own ground) , ORANGE wire into both START & INPUT pin.
would this work?
LowQCab
Joined Nov 6, 2012
5,102
There's not enough information to be able to figure-out what's going on.
That's what You get when You order from China.
Just buy the stuff and play around with it until You can Reverse-Engineer it and
create your own Schematic.
The Printed-Circuit-Board picture looks like both of the Start-Switch-Terminals
are connected together ????
