Hi, I am in Australia.Welcome to AAC!
What country are you in? In the US, light color and brightness are regulated by the Department of Transportation.
yes, I haven’t removed the car factory lights, I am just adding an additional marker on the bumper...... and there are stringent regulations about vehicle lights in the UK and Europe
That's what I assumed. Auxiliary lighting can still cause problems if the colors and intensity don't conform with local regulations.I am adding additional lights to my rear bumper (I still have the car factory lights)
Yes I confirm it is not detailed regulated in my area. Can you possibly help me figure out what can I use to achieve this? ThanksThat's what I assumed. Auxiliary lighting can still cause problems if the colors and intensity don't conform with local regulations.
Can you confirm that this is not regulated in your area?
I am dubious of your claim, but I'll take your word for it.Yes I confirm it is not detailed regulated in my area.
So this auxiliary light has 2 colors and 3 wires?Can you possibly help me figure out what can I use to achieve this?
The light I am using is a proper vehicle-approved lights and the parking LED would need to be feed 8v to get the luminosity required by law.I am dubious of your claim, but I'll take your word for it.
You could insert a power zener diode on the parking break circuit and have the brake light circuit bypass the diode.
the vehicle will be inspected by the local departament of transit before its use as we are doing several modifications (including mechanical itens that will also need to be engineered).In other words, it is illegal to modify the required vehicle lighting unless it meets Department of Transportation (or your local governing body) laws regulating vehicle lighting and may require inspection and certification. Aiding in doing so in violation of the regulations is against our forum rules.
it will be properly validated by our local DOT - while I appreciate your concern I also understand what my local DOT certifiers check in order to get the vehicle compliance so that part is covered. Now back to why I joined the forum, are you able to help me figure out a way to connected these lights? Thank you so much.In other words, it is illegal to modify the legally required vehicle lighting unless it meets Department of Transportation (or your local governing body) laws regulating vehicle lighting and may require inspection and certification. Aiding in doing so in violation of the regulations is against our forum rules. Doesn't matter if you are using DOT-approved parts if the installation is illegal. And, Yes, they sell a LOT of illegal accessories in auto parts stores...
And Welcome to AAC!
I think you'd be better off consulting with someone familiar with your regulations. I don't think you can, or should, install DOT approved lights in non-standard places/applications.The light I am using is a proper vehicle-approved lights and the parking LED would need to be feed 8v to get the luminosity required by law.
[snip]
Would you be able to explain a bit more how I would wire this zener diode?
the aftermarket bumper I purchased it approved to be used in my region and it has three specific places to install a reverse, a turning and a brake/parking light, however these came with incandescent bulbs and now I am replacing to LEDs that’s all.I think you'd be better off consulting with someone familiar with your regulations. I don't think you can, or should, install DOT approved lights in non-standard places/applications.
No mate, I suspect it isn’t much as it’s just 24 leds on each light.Do you have any specs of the current draw of the lights? Is there just one light on each side to be added?
Don't they sell in Australia aftermarket LED lamps to replace your incandescent bulbs? They should be a One-to-One swap. And aftermarket LED lamps are engineered to do exactly what you're looking for. Here in the US my truck uses an 7443 bulb. I can buy an aftermarket LED lamp to be an exact fit and replacement for the 7443. No need to do any special wiring. Just connecting your new lamps to the current automotive wiring harness and you should be good to go.the aftermarket bumper I purchased it approved to be used in my region and it has three specific places to install a reverse, a turning and a brake/parking light, however these came with incandescent bulbs and now I am replacing to LEDs that’s all.
At this point we need all the information you have. Available voltage and product specs. along with what you are trying to accomplish with as much detail as possible. You mention 24 LEDs for each light so what are the specs for the LEDs? You obviously cannot power all in series so we need a Maximum current draw LED spec. to work with.parking LED would need to be feed 8v to get the luminosity required by law.
by Robert Keim
