Test for parking brake engagement on vehicle
Status
Not open for further replies.
fcmagellan
Joined Dec 3, 2024
6
Would connecting a multimeter to a radio harness pin to determine when a parking brake signal is sent to allow video to play, sufficient? What would the setting be on the multimeter? Would I see a low voltage signal? A grounding out/completion of a circuit?
fcmagellan
Joined Dec 3, 2024
6
I appreciate your vigilance but this is for the kids to watch the video in the rear. I wanted to output the video to the rear without spending like $800 on an android system for an older vehicle because new ones are taxed so heavily where I live.
fcmagellan
Joined Dec 3, 2024
6
There are a couple companies that make modules that plug in which probably just ground out the right wire in the back. I guess they are in violation of pocket protector ethics code as well…
panic mode
Joined Oct 10, 2011
5,415
if i understand correctly, you have a car (mystery model, somewhat old) with some integrated entertainment system.
the entertainment system for the passengers in the back only works while parking brake is on.
so you are looking for a way to defeat it so it works any time you like...
perhaps by shorting something or adding some dongle that fakes some signals or whatever...
is that correct? what car?
Ya’akov
Joined Jan 27, 2019
10,350
Welcome to AAC.
Please avoid posts that characterize or insult other members, particularly given your new member status. You are free to disagree with the opinions expressed by others but be aware that while you have no reputation here those who you rhetorically dispose of with facile insults may have a very good reputation—this does not reflect well on you.
I hope you understand the point of this warning, and the spirit in which it is made. You are welcome here, and I hope your time here proves valuable to you.
[MODERATION]
panic mode
Joined Oct 10, 2011
5,415
the fact is that shorting things at random is not a safe approach. i would try to get more info on the devices that do this, obtain service manual and schematics for the vehicle and look at signal involved. i am not going to do it in my spare time for someone else. but if you can find and post more info, you can get feedback on what others could or would do.
Status
