Hello folks,
I'm new to this forum and been reading quite a bit. Thought someone might be able to help me with something
I have setup air ride on my car, that is 4 air bags, one for each corner of the car.
I have an air compressor with a tank which holds air
I have an 8 solenoid valve setup which allows air to go to the air bag, and release air from the air bag
Now the problem,
I have a rocker switch that allows me to activate each air bag, air in and air out.
I would like to setup 3 more switches.
#5 - would allow me to activate the front 4 solenoids, up and down (2 solenoids for up and 2 for down)
#6 - would allow me to activate the rear 4 solenoids, up and down (2 solenoids for up and 2 for down)
#7 - would allow me to activate all 8 solenoids, up and down (4 solenoids for up and 4 for down)
note: I am using 4, 3 pin momentary SPDT switches
and have 2, 6 pin momentary SPDT switches for the front and rear up and down
Is it possible to only use the 3 pin, and how to wire the 7th.
Any help on configuring the entire thing would be great.
should I use relays, mosfet, etc...
Thank you so much
Now the problem,
Thank you so much
