Capacitor Voltage Sign notation
Vihaan@123
Joined Oct 7, 2025
288
Fig1
I am bit confused of the arrow direction of Vc and V0. The derivation is as below
I get that -Ve sign which is not available in the answer.
And in equation 2, should it be -V0 or +V0 for 250V initial voltage. Please guide me to write the correct equations.
WBahn
Joined Mar 31, 2012
33,122
The diagram tells you the polarity of Vo (the initial voltage). It's magnitude is given in the problem.
Your equation has V(s) in it, but that is not defined anywhere.
Look at the circuit and, without doing any math, ask yourself whether you expect the current i to be positive or negative given the initial voltage on the capacitor.
Vihaan@123
Joined Oct 7, 2025
288
The capacitor equation i converted to Laplace transform.
The current direction shall be the same as shown in the circuit but i get negative it means it is flowing in the opposite direction to the one shown in the diagram which i feel is not correct.
WBahn
Joined Mar 31, 2012
33,122
Look at your starting point there.
If i(t) is positive, your equation says that dV/dt is positive, and therefore the voltage on the capacitor, v_c, is increasing (algebraically going from less positive to more positive).
Now look at the circuit and the definitions of i(t) and v_c(t) and see if that makes sense.
Vihaan@123
Joined Oct 7, 2025
288
Thank you very much for the continuous support.
I will explain the way i learnt KVL equation, if i go in the direction of arrow of current there will be drop in capacitor voltage Vc and hence it is +ve at lower side and -ve at the upper side and similarly for the resistor.
For V0 i assume it is a kind of DC source for the current to be in the direction taken, the -Ve will be at the bottom and +Ve at the top as indicated. Am i correct up to this point? I do not draw the arrows as indicated in the problem diagram and do not know how to do it for the voltages. 1764216112840.png
The KVL equation is
-Vc-Vr=0 => Vc+Vr=0 ->eq1
The capacitor equation in this case
i = Cdv/dt -> eq 2 even voltage is decreasing but maintaining the same current direction i am writing it as positive is it correct?
If i solve the equation with i = -Cdv/dt i am not getting the correct answer.
The only way i am getting the correct sign and magnitude is when i put
I(s) = C(sV(s) + V0) -> eq3. instead of I(s) = C(sV(s) - V0)
So i am confused on the initial conditions shall i put V0 or -V0, how do i know? Or some other fundamental mistake i am making can you help please.
Vihaan@123
Joined Oct 7, 2025
288
There is something wrong if i calculate the voltage equation i am getting +Ve but the answer is -Ve. I need to re work again.
WBahn
Joined Mar 31, 2012
33,122
Let's start with the fundamentals.
By the definition of capacitance, we have
Q(t) \; = \; C \cdot v_c(t)
But Q is just the time integral of i(t) and, if we have an initial charge of Qo at t=0, then
Q(t) \; = \; Q_0 \; + \; \int_0^t i_c(t) \; dt \\
\frac{Q(t)}{C} \; = \; \frac{Q_0}{C} \; + \; \frac{1}{C}\int_0^t i_c(t) \; dt \\
v_c(t) \; = \; V_0 \; + \; \frac{1}{C}\int_0^t i_c(t) \; dt
Now take the Laplace Transform of both sides:
V_c(s) \; = \; \frac{V_0}{s} \; + \; \frac{I_c(s)}{Cs} \\
I_c(s) \; = \; Cs \cdot V_c(s) - CV_0
This is for i_c(t), v_c(t), and Vo defined as shown above.
Carefully express the quantities defined in the diagram in terms of these quantities and you should get the correct answer.
Vihaan@123
Joined Oct 7, 2025
288
Yes now i got the correct values
i(t) =
vc(t) =
MrAl
Joined Jun 17, 2014
13,785
Fig1
Hello there,
This looks like they are giving the initial condition voltage with initial polarity, and also giving the voltage measurement polarity.
The initial condition voltage is Vo with positive on top.
The way they want you to measure the cap voltage Vc though is with the positive on bottom.
This means that the initial voltage is actually -Vo.
If Vo=2v then Vc=-2v.
If Vo=-2v then Vc=+2v.
Any solution to the cap voltage has to conform to the measurement of Vc. If you used a voltmeter the positive lead would be connected to the bottom of the cap and the negative lead connected to the top of the cap.
For example, normally we would see a cap charging expression as:
Vc=Vc0*(1-e^(-t/RC))
but if the measurement was taken in reverse like the problem you are doing, it would be:
Vc=-Vc0*(1-e^(-t/RC))
So the polarity of the initial condition voltage may be different than the measurement of that voltage.
This is also true with initial condition currents and measurements.
In general, the measurement polarity can be different than anything else in the circuit because it has its own convention.
In some cases we don't see any voltage polarity indications at all. In those cases we usually infer the polarities based on the ground connections and anything else that might give us a clue such as a positive or negative power supply voltage.
As to the diode current arrow, that tells us we are measuring current from left to right in the diode, so from anode to cathode which is the forward current. If that forward current was 1 amp then i=+1 amp. If that arrow was reversed, then the forward current would be measured at -1 amp.
If we said that the current from anode to cathode was -1ua, then that would be a leakage current.
As a quick illustration, take a look at the attachment.
Then, ask how do we measure the capacitor voltage, the diode current, and the voltage across the resistor.
