hi,
What do you expect M2 to do in this circuit.?
E
E
This is the problem. While M1 is ON, voltage across R7 should be 600V, but instead it is 11V. Please suggest any edit in the circuit.If M1 is ON, then V5 voltage will be across R7, so current will flow in R7, assuming that M2 is OFF
Yes now I understand what is happening. What should I do in order to make this circuit working?so M1 will only be partially conducting, so the R7 voltage will be very low.
by Robert Keim
