Cant figure this circuit out
dl324
Joined Mar 30, 2015
18,521
I did see post #16
These requirements are garbage. You can't have 3V out with 3V in using TL341 with a pass transistor.
Supply voltage: 3Vdc to 12Vdc
Output voltage: 3Vdc to 7Vdc. Output voltage not exceeding supply voltage of course. So if its 4vdc supply voltage then ouput voltage 3vdc to 4vdc. If supply is 3bdc then output voltage is 3vdc. If supply voltage is 7vdc then output voltage 3vdc to 7vdc. Etc etc
Output current: 100mA to 7A. The output current should not exceed output voltage. Meaning if vout is 3V max output is 3A. 4V out then output is 4A. 7V max output is 7A. Etc etc
hhsting
Joined Apr 25, 2024
395
#19 says possible??
Anyway let me rethink it how about this:
Supply voltage: 3vdc to 12Vdc
Output voltage: 3.3vdc to 7Vdc. Output voltage not exceeding supply voltage of course. So if its 4vdc supply voltage then ouput voltage 3vdc to 4vdc. If supply is 3bdc then output voltage is 3vdc. If supply voltage is 7vdc then output voltage 3vdc to 7vdc. Etc etc
if not that then what output voltage is possible?
dl324
Joined Mar 30, 2015
18,521
#19 says possible??
This is what it said. Nowhere does it say what you from a TL431 and a pass transistor is possible.
But you are still aiming for a dropout voltage of zero. That circuit doesn't do zero drop-out.
You can replace the transistor with a MOSFET. It will then need no gate current, so the output current is only limited by the MOSFET itself.
However, the minimum dropout is equivalent to Vgs of the MOSFET for the output current required, and that is going to be higher than it is for a bipolar transistor.
You're going to have a dropout voltage, even with an LDO regulator.
A buck boost regulator is a possibility. It will be challenging for the currents you want.
hhsting
Joined Apr 25, 2024
395
I have no idea what you are saying. Show circuit and illustrate it please
Papabravo
Joined Feb 24, 2006
22,116
Please help
I'm going to try. The immutable rule of DC-DC power conversion schemes is the following:
Output power will always be less than input power. Sometimes it will be a great deal less.​
Power, measured in watts, is voltage times current, and for DC-DC conversion this quantity is easily calculated. The ratio of output power available to input power available is the efficiency and that quantity will always be less than one for any real system.
Go back to your specifications and tell me which ones satisfy the criteria and which one do not. Going forward, apply this test to all future specifications to avoid the opprobrium being heaped on your person by those in the know.
Example: Suppose I want a 12 VDC output from a 3 VDC source and the output power required is 12 watts. In other words, the output current should be a maximum of 1 Ampere. For purposes of illustration, we pick a target efficiency of 88%. In practice we might be able to do better, but we might also end up doing worse for a variety of reasons.
Question: What is the required input power and input current for this DC-DC conversion scheme?
Answers:
(a) 12 watts / 88% ≈ 13.6 watts of required input power
(b) 13.6 watts / 3 VDC ≈ 4.5 Amperes of required input current
If the required input power is not available for some reason, most DC-DC conversion schemes will adapt by changing either the output voltage or the output current or both. This is a useful piece of information when debugging DC-DC converters that are not behaving as expected.
k1ng 1337
Joined Sep 11, 2020
1,038
If you haven't already, try simulating the circuit in LTspice. Provided the circuit you supplied will reach steady state, use the voltage and current values found in spice to build your own equations. I use this method to confirm equations or to help fill in the blanks when things don't make sense. Spice is a powerful calculator if you know how to use it and it's well worth the time investment. I can provide an example if you'd like.
hhsting
Joined Apr 25, 2024
395
I can simulate circuit post#1. I just need transistor that has hfe greater then 40.
Anyone know of any?
If i need example i let you know
thanks
Ian0
Joined Aug 7, 2020
13,317
Haha that's just cruel.
A Darlington has a larger inherent voltage drop, this makes things worse, not better.
Well . . . it's not going to work if the Hfe is too low, and it's not going to work if the voltage drop is too high.
Because it's not a high-current low-drop-out regulator circuit, and nothing will make it so.
hhsting
Joined Apr 25, 2024
395
Well then what transistor has hfe higher than 40?
Ian0
Joined Aug 7, 2020
13,317
But you just said Darlington has high voltage drop and not going to work?
Any other circuit configuration that will work?
You wanted 3V out from 3V in. That's not going to happen with an ordinary bipolar transistor either. Your circuit needs about 3V dropout voltage to work satisfactorily, and then it would work with bipolar, darlington or MOSFET (though with an ordinary bipolar transistor the output current will be restricted)
hhsting
Joined Apr 25, 2024
395
how would one do a 3V dropout then?
