Can't calculate the resistance
Adlh
Joined Mar 1, 2015
5
So I have this circuit that I have to calculate the resistance in and I have no idea how to add them up. I'm confused by the short circuit and how it has affected the wiringUntitled.png
35,282
How does one measure resistance?
Apply a voltage source across A-B and measure the current through that leg.
It doesn't matter what voltage you apply but try 50V for starters.
Solve by applying KVL and KCL.
Adlh
Joined Mar 1, 2015
5
First Yes I know how to add series and parallel resistors, its just that the short circuit completely confused me on how the current would flow. Without the short circuit it would have been an extremely easy question.
Yes I think the 2 circuits above are equivalent to each other with how the current flows in both of them.
Adlh
Joined Mar 1, 2015
5
So now you have everything you need to solve the problem?
Yeah I'll do it a little later since I skipped this question and I'm doing the rest. Thank you for you help on clearing up the connections, I appreciate it!
