Can't break a while loop in Arduino
M3D0
Joined Oct 8, 2020
54
Hello Everyone! For the last two days, I've been trying to write a code that keeps doing/activating a LED till a button is pushed to get out of the while loop and continue the rest of the code. I have tried the following approaches to solve this problem and didn't work:
1)creating another void function that is being called in while loop
2)putting an if condition inside the while loop to check again if the button is pressed or not to execute [break; ]
3) using "do ...while" loop
(N.B: I did simplify the theory of operation as the button in the original code will be a sensor that has a digital output, I just want to focus on how do I get out of the loop and continue executing the rest of the code)
Thanks in advance!
simple Arduino while loop code:
const int reqg = 3; //button pin
int BUTTONstateg = 0; //button state
const int LED1 = 7; // led1 pin
const int LED2 =8 ; // led2 pin
void setup() {
  pinMode(reqg, INPUT); //setting the buuton pin as an input
  pinMode(LED1, OUTPUT); //setting the buuton pin as an input
  pinMode(LED2, OUTPUT); //setting the buuton pin as an input
  Serial.begin(9600);// setup Serial Monitor to display information
void loop (){
  BUTTONstateg = digitalRead(reqg); //getting reading from the button
  while (BUTTONstateg == LOW ){
    delay(1000);
    digitalWrite(LED1, HIGH); //LED1 is on till the button is pressed
    Serial.println("in while loop");
  digitalWrite(LED2, HIGH);//LED2 supposed to be on when the button is pressed so the while loop is no longer being executed
  Serial.println("out from while loop (which I can't reach it)");
djsfantasi
Joined Apr 11, 2010
9,237
Thanks in advance!
void setup() {
void loop (){
    delay(1000);
First, there is a command to force an exit from loops. Look at the break command.
BUT, that’s not your problem. Once you enter the whole loop, you never check the button state again! So, of course you’ll never exit.
Insert a digital read of the button inside the while loop. You’ll need a second read to check the button state. You’ll still need the first read to get the initial button state.
ErnieM
Joined Apr 24, 2011
8,415
The main void loop(void) is already an endless loop so there is no need to create another.
I would write the loop like so:
C:
void loop (){
  if (digitalRead(reqg) == LOW)    // Check the button
    digitalWrite(LED2, LOW);
    Serial.println("Button LOW");
  else
    digitalWrite(LED1, LOW)
    Serial.println("Button HIGH");
  delay(1000);
BobaMosfet
Joined Jul 1, 2009
2,211
Thanks in advance!
void setup() {
void loop (){
    delay(1000);
Title: Standard C [Quick Ref]
Author(s): P.J.Plauger, Jim Brodie
ISBN: 1-55615-158-6
djsfantasi
Joined Apr 11, 2010
9,237
The TS hasn’t responded to his thread since his initial post. It’s been two days. Anyone else think he’s got an answer elsewhere?
