Thanks ABSF for the response.The schematic is just to cool. Using a clamp on ammeter at yourAgreed with dl324. My simulation shows that there is a 27V drop on the Rload with a current of 1.36A through the FET.
If you are not getting any voltage drop across your load, the FET is probably gone.
rl2 read 0 amps. Would you suspect our choice of FET is to whimpy for this task? If so what FET would you suggest and any other parts of the ckt need changing or adding to make this ckt work? We appreciate what you have done so far.
Dennis Bequette DENARA
