Can you help me understand these numbers ?
Hextejas
Joined Sep 29, 2017
187
I have stepped back from the inverter and am now working on this.
I got it working ok,no smoke but I am trying to relate the answers that I get from the equation, f= 1/RC*4.4, with what I measure and see.
I used 2 different combinations of R and C with the following results.
1) R=2977 ohms, C=100 uf. When I measure the OSC freq it measures 1.32hz and I can see the light blinking at a bit faster than once a second. The Q and Q* lights are blinking at roughly 1/2 the speed of OSC. The result of the equation yielded .007634287. How does that equate to what i measure and observe ?
2) R=47k, C=100uf. Audioguru recommended these values to get close to 50hz. The ORC measures at 97hz and the lights are on solid. I guess to be expected if 97hz. The result of the equation yielded .47846. How does this equate to 50hz ?
Thanks
George KG5TKY
18,127
Watch your units and order of operation. The formula likely expects R and C in ohms and farads respectively although you should check that. Be sure you’re applying the 4.4 factor properly. And the realize the combined errors of components values and measurements can give measured values wide of the calculated values.
And yeah, you can’t see 100Hz.
34,952
I did not check your numbers.
Yes, the Q and /Q outputs will be exactly one-half the frequency of the oscillator. The chip is designed to do exactly that.
As @wayneh implies, an LED flashing at 100Hz would look as if it is solidly ON, even though it is flashing.
Hextejas
Joined Sep 29, 2017
187
I think I did the order properly they are all *. The number of 000s is something else again.
Audioguru
Joined Dec 20, 2007
11,248
My schematic shows 47k and 100nF. 100nF is 0.1uF, not 100uF.
Then the oscillator runs at 96.7Hz and the two outputs are 48.4Hz.
1/20.68ms =48.4Hz.
Dodgydave
Joined Jun 22, 2012
11,395
I would say if you want 50Hz at the Q/Q- outputs, use a 45K resistor with a 1K preset, and 100nF cap.
Output F= 1/ 4.4 x RC
Hextejas
Joined Sep 29, 2017
187
Thank you all for your replies. Since I am getting close to getting this to work, my next questions are:
I don't have a scope yet but isn't the output of OSC a square waveform sorta like AC ?
And can't I turn that into a proper AC waveform ? ( whatever proper means ).
I will want it to be a lot less than 110 volt.
Another question. Whenever I see an inverter schematic, they use Q and Q* to feed the xformer.
Why not use OSC ?
AlbertHall
Joined Jun 4, 2014
12,636
The OSC output is not necessarily 50:50 mark space ratio and would result in a net DC component in the transformer primary which they do not like. The Q and Q* will be 50:50 and so is good for driving a transformer.
34,952
OSC output is 0-5V.
Using Q and Q* on the transformer would constitute a bridged output. Hence you get twice the voltage on the transformer.
Audioguru
Joined Dec 20, 2007
11,248
A squarewave inverter is an extremely simple circuit. Its output will drive heating appliances or incandescent light bulbs that are also heaters. 110VAC electricity is a sinewave with a peak voltage of 110V x 1.414= 155.5V which many modern electronic products need. But you do not want a squarewave inverter to produce 155.5V peaks because then it will burn out heaters and incandescent light bulbs that use a 110V sinewave.
A good modern inverter produces a sinewave. A cheaper modern inverter produces a modified sinewave that is actually a modified squarewave like this:
