Can you help me find which inductor I need?
ronsimpson
Joined Oct 7, 2019
4,793
Where is the "fb" pin? Pin-4?
link Link to DigiKey.com looking for 100uH >7A <0.04ohm surface inductor.
TI.com said 9A but I think 7A is probably enough. I know you are only going to use 3.5A but the part will make much more under a short or heavy load.
If you want to expand your options a little try 80uH to 120uH and there should be more options.
IT's tools come up with this. (using the ADJ version)
for the inductor they said:
Miracletech
Joined Nov 15, 2019
160
That would be a bettter option.
