Help to find datasheet for SMD device marked E50H
Dave Lowther
Joined Sep 8, 2016
347
I just bought a strip of 5 boost converters from Amazon:
I'm interested in reading the datasheet for the only device with more than two leads, which hopefully is the boost converter chip. I've taken these photos:
I've not had any success searching the internet for "E50H data sheet" or "E5OH data sheet". Nor for various other search terms including "boost converter".
If you know how I can get hold of the data sheet for this please let me know the URL or what I should be searching for.
TIA
Dave
sparky 1
Joined Nov 3, 2018
1,218
not absolutely sure if ±2.5% or ±1% there are 300kHz also
E50
XC6382A501M
Torex Semiconductor
SOT-23
DC/DC voltage converter IC
PFM step-up, 5.0V±2.5%, 400mA, 100kHz
I bought the same module and I am also looking for the datasheet . It seems this data sheet: https://product.torexsemi.com/system/files/series/xc6371.pdf is closer as the application circuits is exactly what I can see.
Unfortunatly the marking is not exactly corresponding.
Thanks for the beguinning of the track
All this is a little bit confusing, on xc6382 datasheet marking E50? exist but is for xc6382A (SOT89) and obiously, on my board, output is on pin2 then it should be a xc6382B with F marking.....
