Help me find a part like this but different!
Tonyr1084
Joined Sep 24, 2015
9,744
Pins 1 & 4 are Source
Pins 2 & 5 are Gate
Pins 3 & 6 are Drain
Q1 is N channel
Q2 si P channel
Orient the chip according to where you want Q1 and Q2.
sparky 1
Joined Nov 3, 2018
1,218
If the availability price reflects a trend toward 2 18650 LiPO The standard would or already is 7.2 - 8.4 V minamal polarity +-3.6, having said that
Possibly N and P channel could gravitate toward an allocation for preassembled on adapter board with heatsink.
Then previous application types may not be the best for dual 18650. There was a move toward these chargers.
NTJD4105C - MOSFET – Small Signal, Complementary, SC-88 20 V / -8.0 V, +0.63 A / -0.775 A
Ramussons
Joined May 3, 2013
1,572
The chip construction is
Pin 1 = Pin 4 = Source
Pin 2 = Pin 5 = Gate
Pin 3 = Pin 6 = Drain
1-2-3 is N,
4-5-6 is P
Rotating by 180 keeps the S-G-D layout the same, except the Polarity.
BobTPH
Joined Jun 5, 2013
11,659
1-2-3 is N,
4-5-6 is P
Yes, but according to the previous post, the schematic had source and drain swapped on one of them. Rotating the part won’t fix that.
