Can this schematic actually produce 12V 60A output?
Deleted member 440916
Joined Dec 31, 1969
Trafo design is rubbish, skin depth at 50Khz is ~0.3mm, this joke schematic uses 1.3 & 1.7mm wire lols
Simple answer to OP is NO chance!!
Ian0
Joined Aug 7, 2020
13,317
Those MOSFETs are going to be really upset by that amount of capacitive load. Unless it's LLC resonant, then it needs an output inductor.
At that voltage, the output diode should be a schottky.
laco22
Joined Oct 31, 2017
20
Thank you all for your replies.
Perhaps I don't have a lot of knowledge in this field.
I will try while learning a little more.
DickCappels
Joined Aug 21, 2008
10,661
If this is your first switching power supply project, I think you will do much better to start out with a lower voltage and lower power design like one in an application note or semiconductor datasheet. The schematic show signs of not being designed as much as being discovered.
Your first switching supply should not cost much and not be dangerous to work on this seems to be both expensive and dangerous. As @fourtytwo pointed out the transformer is entirely wrong for this application. Sadly, I would be very surprised it it works at all as drawn.
LowQCab
Joined Nov 6, 2012
5,102
SMPS's are NOT a beginner project.
Especially extremely High Current versions.
Start looking for a "MOT" (Microwave Oven Transformer).
Any used Microwave Oven will work.
Check-out the hundreds of Videos on YouTube on how to Modify any "MOT".
You will need to remove the Secondary Windings, and the "Magnetic Shunts" from the Core,
then it is simply a matter of obtaining some #6-gauge, Fine Stranded, High Temperature Insulated, Wire.
You will probably need less than 16 Turns of Wire on the Core to get 12 Volts AC,
just keep adding Turns until you get the Voltage you want.
Smaller Gauge Wire will melt and cause a FIRE at ~60 Amps, DON'T SCRIMP ON THE WIRE.
One single Electrolytic Capacitor is not going to survive ~60 Amps,
you will need more like 10 to 15 smaller Caps that are RATED FOR THAT MUCH RIPPLE CURRENT,
like 15 of these .......... EGPD350ELL752MM40H ...... from DigiKey Electronics.
15 X $3.96 = $59.40, 35V, 7500mfd, which can handle 6-Amps of "Ripple-Current" @120hz.
So that's, 15 X 7500mfd = 112,500mfd, at, 15 X 6A = 90Amps Ripple Current.
Then you need a Bridge Rectifier ........ Well it seems that they don't make them that big,
so you'll have to cobble-up your own out of 4- individual Diodes,
like these ........ VS-150EBU02 ...... Also from DigiKey,
4 X $7.05 = $28.oo, 200-Volts, 150-Amps,
These Diodes will require careful attention to how the Physical Connections are made to them,
and how they are mounted to the Heat-Sink,
60-Amps is NOT a trivial matter, minimum #6-Gauge Wire.
These Diodes will also have to be mounted on a proper Large Heat-Sink because
they will Dissipate..... 0.8V X 60A = 48-Watts EACH (192 Watts Total), under a 60-Amp Load,
and so the Heat Sink will have to have a Cooling Fan to keep temps under control.
12-V X 60-A = 720 Watts,
this is probably the maximum rated Wattage for your average Microwave-Oven-Transformer,
and they are not rated for continuous duty, so the Transformer may need a Cooling Fan as well.
This is basically a well filtered DC- Arc-Welder.
It will start most small Cars without the help of a Battery.
Very few Batteries can withstand being Charged with 60-Amps for more than a few minutes.
Are you still sure that you need 60-Amps ????
jpanhalt
Joined Jan 18, 2008
11,087
Ha, ha. Where do you live? Microwaves are in the 1200W range, as is my Sears Kenmore that is a 27-year old one.
As for a 720W arc welders, even the cheapest at Harbor Freight is 2400W supply (20A @ 120V).
laco22
Joined Oct 31, 2017
20
Thank you for answer.
There seems to be a part that I thought very easily.
I can't understand all of your words right now, but I will study according to what you said.
And, I need 60A is right.
LowQCab
Joined Nov 6, 2012
5,102
Maybe you can use 2- Large Computer Power Supplies ?
Can you split your Load in to 2- Parts ?
( If you need more than "exactly" 12-Volts,
the Computer Power Supplies will have to be Modified to increase Voltage Output ).
Automotive Battery Chargers require 14 to 17 Volts to work.
laco22
Joined Oct 31, 2017
20
The load can be divided into 30A and 30A respectively.
The load is a large-capacity LED panel.
The first and second floors are divided, so they can be divided.
The led panels only need 12V.
Thanks.
