Can someone help me review this schematic? (AT89C52)
redgear
Joined Oct 17, 2019
136
I am a beginner and I have got few questions with the first project I am attempting. I am trying to build a reliable timer circuit with three timing options. The use case is very similar to a microwave oven i.e., the circuit should check if the doors are closed, three timing options that can be selected with the buttons, start, stop and pause options for the timer.
I first thought of using a 556 timer(restricting to only two timing options) with a relay. But I also needed a display(lcd displays, not 7 segment leds) and it was not possible to interface a display with the 556 timer.
Another option was to go with a microcontroller like arduino which is easy to work with but I'm sure about the reliability. And they also cost more.
I was searching online and found this circuit for a microwave oven controller. I'm thinking to modify this to my needs than trying to build it from scratch. I have few questions:
  1. I am not able to find AT89C52, what else can I replace it with? Will any 8-bit 8051 do fine?
  2. I just need to control one relay and 5 input switches. Can I just leave the other ones floating?
  3. This circuit is designed to work with high power components while my total power usage will be around 80W, do I need to re-calculate for the resistors and capacitors?
The circuit has no fuse on the AC lines. I will be adding a 5A fuse.
Picbuster
Joined Dec 2, 2013
1,059
At the first glance I do see a problem with the rst circuit;
You try to put the rst switch parallel to a 10u Capacitor this need resistor in serial allowing power consumption when pressed.
Picbuster
redgear
Joined Oct 17, 2019
136
Picbuster
Thank you!
Does the rest of the circuit look fine? Do I not need to recalculate values for Caps and resistors if I plan to use it only for low power(~80W). Can I leave the connections to switches that I do not use floating?
absf
Joined Dec 29, 2010
1,968
I found your circuit from the EFY forum and the author also included the software in Keil C and Hex codes.
I recommend not to use the 89C52 as it does not support the ISP method of programming. You might have to program it with a DIY programmer interfaced to the PC parallel port.
Instead you can use the newer 89S52 from Atmel which supports ISP programming.
The link I found was HERE.
https://www.electronicsforu.com/electronics-projects/microwave-oven-control-board-2
Allen
