Can I use more powerful laptop adapter
Martiio
Joined Apr 2, 2020
50
Hello, Can somebody tell me Can I use 19.5v 6.32A laptop charger instead 19v 3.42A charger.I bought a used toshiba laptop without charger and I have got from my previous laptop 19.5v 6.32A charger.
dl324
Joined Mar 30, 2015
18,453
if the voltage is with 0.5v higher is that a problem?
Can't say definitively without more information. The voltage tolerance of the laptop, the nominal output voltage (actual) of both adapters. The laptop information might be difficult to obtain because manufacturers expect you to use the provided adapter.
EDIT: FWIW, I measured an unloaded voltage of 19.4V from an HP adapter that states it's 18.5V @ 3.5A.
