can i use 2sc5200 for voltage regulator?
dl324
Joined Mar 30, 2015
18,418
With adequate heatsinking, it could be used as the pass transistor. The beta could be as low as 35 at 7A, so you might want a Darlington configuration if you want high current.
To get relevant suggestions, you should post in your original power supply/regulator thread.
