Can brass and or bronze be soldered to copper?
cmartinez
Joined Jan 17, 2007
8,887
I need to install an en electrical conductor through a piece of acrylic, and it seems that brass screws are ideal for this application. Question, can ordinary electronic solder (SN60PB40) be used to join a copper wire to a brass screw?
shortbus
Joined Sep 30, 2009
10,049
Sure I've done it most of my life, soldering brass to copper. But depending on the size of the screw you might need more heat than a small electronics size iron can give. I have always used a Weller solder gun.
MaxHeadRoom
Joined Jul 18, 2013
30,881
If the joint receives any flexing I would look at low temp silver solder using a small torch. Especially if any significant current flow.
Max.
cmartinez
Joined Jan 17, 2007
8,887
Max.
Nah ... the joint will neither be flexed or suffer vibration. And the amount of current will be quite low, and also the voltage. That's why it's important that I don't use stainless steel for these screws, so as to keep power losses to a minimum.
There's a local supplier that sells copper screws, but not the size that I need. They do have more variety on brass screws, though. That's why I've asked if brass and copper solder well together.
SLK001
Joined Nov 29, 2011
1,549
Yes, they do, but it is not a good idea to do so. A sufficiently tightened screw should be enough to guarantee an airtight joint. Don't depend on solder to do this (as we have discussed many times here).
cmartinez
Joined Jan 17, 2007
8,887
Thanks for the advice, but I wasn't planning on doing things that way. My plan is to solder the wire to the head of the screw. The flat bottom of the screw's head will be pressing against the acrylic, with an o-ring between them acting as a sealant.
Tonyr1084
Joined Sep 24, 2015
9,744
You asked about bronze. You DO know bronze is an alloy of copper and brass. Therefore, the answer regarding bronze would also be "Yes".
cmartinez
Joined Jan 17, 2007
8,887
Actually, Bronze is an alloy of copper and tin, while Brass is copper and zinc.
It's the presence of tin and zinc in those alloys that had me wondering if they'd affect common electronic solder.
SLK001
Joined Nov 29, 2011
1,549
Actually both tin and copper are solderable, so I don't see any problems with soldering bronze (provided the alloy is just those two elements).
ebp
Joined Feb 8, 2018
2,332
Zillions of plumbing joints are copper soft-soldered to brass (mostly) or bronze (less common). Lead-free solder is now the standard for plumbing, and produces stronger joints. Though no longer true in plumbing, many brass alloys contain some lead, which acts as a sort of built-in machining lubricant.
Various brass and bronze alloys are extremely common in electromechanical devices such as relays. For example, the moving contacts in relays may be mounted on bronze alloy spring "fingers" which have wires soldered between them and the brass pins that get soldered to a PCB or plugged into a socket.
Model railroaders solder up all manner of things from brass.
About the only common metal that is very difficult to solder is aluminum. Stainless steel can be very difficult to solder if not prepared (freshly abraded to remove chromium oxide at the surface, which is what makes it stainless. I use 300 series welding filler wire for assorted things. As-is, no flux is adequate to allow it to be soldered, but a little work with 600 emery or the like will make it readily solderable with fully-activate rosin flux.). The wikipedia page on solderability give a rundown.
ebp
Joined Feb 8, 2018
2,332
Never never never solder stranded wire with zinc chloride flux unless you only need it to last for a short time. Molten flux will wick up among the strands where it is virtually impossible to remove by washing. Zinc chloride leads to a perpetual corrosion cycle - chlorine is a powerful oxidant and will react readily with the metal. The metal chloride can then react with carbon dioxide, producing metal carbonate and freeing up the chlorine to react with more metal in a process that continues as long as there is no more metal to destroy. Even the lead in solder is vulnerable to this. Somewhere out there there is a paper from one of the big solder manufacturers that describes this, but I can't find it.
I've soldered all sorts of brass things with ordinary electronic solder with activated rosin flux with no difficulty, provided the brass was properly cleaned. Clean brass is usually easy to solder even with RMA and no-clean fluxes. I just tested on some freshly cleaned thin sheet brass with 5 different kinds of electronic solders (RA, RMA, 3 no-cleans including one that is really "weak") and they all worked well. I have used brass tubing and washers as housings for in-line ultrasonic pre-amps and soldered them with RA-cored wire solder with no difficulty, though everything was always freshly cleaned. Microdot connectors were soldered to brazed-on brass nuts with the same solder. I designed in 10-32 brass machine screws with nuts as terminals for an industrial battery charger PCB. Both the head of the screw and the nut were soldered to the board during normal wave soldering (strategically-placed vias allowed the solder to flow to the top surface of the board to solder the nuts to keep them from turning).
cmartinez
Joined Jan 17, 2007
8,887
Thanks for the warning, somewhere in the back of my head that's information that I had already learned, many years ago. Thanks for bringing it back to the surface. On the other hand, it is magnet wire that I'll be soldering, so the effect that you're describing will not be a problem, and the joint is something that I can easily wash after soldering.
