Can anyone identify these switches please?
pauldee
Joined Aug 5, 2025
I'm trying to find a replacement for these switches. They have T85 embossed on them and 10/06 printed. They are PCB horizontal mount and only have two contacts so probably SPST? They are from a motorhome cooker hood which is basically noting more than a housing for these switches but costs £500, so any help would be greatly appreciated!
meth
Joined May 21, 2016
316
The closest thing I have seen are Alps SPUN switches. I am guessing the black part is only a cap. Although I havent seen SPST Alps SPUN switch.
Maybe this could be a starting point to find your switch.
MaxHeadRoom
Joined Jul 18, 2013
30,815
Worst-case scenario, you could always fit some separately mounted PB switches that are latch-on latch-off , they are quite plentiful, find out what current rating you need first.
pauldee
Joined Aug 5, 2025
The ALPS SPUN are similar but not exact. I'm thinking I might just knock up a new PCB, wouldn't be hard
Werecow
Joined Aug 4, 2025
37
They look very similar to Seuffer switches, although not identical. Maybe these would work?
Edit: On closer inspection, it's a Seuffer-branded PCB, so that makes sense. :)
Werecow
Joined Aug 4, 2025
37
Since these are being sold as power switches, they're probably push on/push off vs. what appear to be momentary switches in your photos, but the latching function can usually be defeated fairly easily.
pauldee
Joined Aug 5, 2025
Mine are latching/power switches
35,195
If you are capable of making your own PCB, I would go that route and choose a more common off-the-shelf switch.
Then you will be able to replace the switches when necessary.
